Cheap Chinese carbo...
[Closed] Cheap Chinese carbon bars and titanium skewers. Any good?
[#6548164]
I know there's been a few threads on cheap Chinese carbon frames, and I think the general consensus was that they are good value for money and just as durable as the well known brands.
What about components though?
These two in particular.
[url= http://www.ebay.co.uk/itm/31-8mm-3K-Carbon-Fiber-Handlebar-Mountain-MTB-Bike-Cycling-Bicycle-Riser-Bar-New-/311022886605?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item486a689ecd ]Carbon bars for £14.[/url]
[url= http://www.ebay.co.uk/itm/Titanium-Skewers-100mm-135mm-Bike-MTB-Quick-Release-48g-pair-5-Colors-/251674238797?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item3a98f41f4d ]Titanium skewers for £7[/url]
Are they all made in the same factory and it's just that these haven't got a known brand name printed on them at the end of the production line, or are they some dodgy substandard rip off?
Worth buying or not? I mean, cheap bars and skewers, what could possibly go wrong?
Posted : 12/10/2014 10:19 am
I wouldn't. 2 areas you really don't want failing.
Posted : 12/10/2014 10:28 am
With your reputation? : )
Why bother.. I don't wreck as much kit and I'd always use RWS or XT skewers and reputable bars.
Posted : 12/10/2014 10:37 am
I've been running a chinese road frame for the last 3 years as a training bike. I originally had a one piece bars/stem combo and had no issues. I changed it out for a longer stem.
Can't really comment on mtb bars. Must admit, in the 2004 Enduro I'm building up I'll get a set of Renthal's, road riding is one thing but on the trails is something else.
Posted : 12/10/2014 10:39 am
I believe i'll be buying a Chinese carbon full sus next year when I get the pennies together... So I'm sold on the Chinese carbon front...
However, I probably wouldn't get Chinese carbon bars... Doesn't sit right in my head... But I don't doubt that some big brand bars are made in teh same factory!
Posted : 12/10/2014 11:49 am
 DT78
I just found some cracks in my rather expensive 3t carbon roadie bars so I don't think failures are restricted to Chinese direct stuff 🙁
My LB rims (only thing I've got experience off) have been great so far and taken a beating.
Posted : 12/10/2014 11:52 am
 nach
Don't bother with those skewers, they have a really weak clamping force because of the way ti can stretch. I had some that seemed fine with a Spesh Hardrock, but when I put one on the back of a Blue Pig, on the second ride it kicked the back wheel out on a climb and bent the brake side dropout. I'd checked the skewer was tight before setting off, and would have been screwed if the frame wasn't steel. Once I googled it, I found plenty of people who'd had similar experiences with various brands of them.
Posted : 12/10/2014 12:08 pm
I'll send a card to the hospital when it explodes 😀
Posted : 12/10/2014 12:12 pm
I've got those exact skewers, they're pretty naff. They come undone even if you clamp them down tight and they're not made of titanium, it even says Aluminium on the packet when you get them.
Posted : 12/10/2014 12:18 pm
Beaconjon. Check out the OnOne carbon bars that were on a thread yesterday - Knuckleball I think they were called. £39 for carbon bars with 5 year defect warranty seems good.
Posted : 12/10/2014 12:30 pm
I'd heard that titanium at any price was the wrong material for a skewer
It stretches more under tension so you can't get enough load
Tech note
There is no way round this all Ti has the same Young's Modulus and it always lower than the Young's Modulus for steel
Posted : 12/10/2014 1:48 pm
You have no idea.
There is not one Chinese Carbon Bike Part Factory, I love my Chinese made carbon frame, it came with a 5 year warranty, lots and lots of R&D and testing and a solid reputation from Santa Cruz.
Posted : 12/10/2014 1:51 pm
I too mocked Chinese carbon for years ..... Berating all who bought and used it....
Now I have
road wheels(farsports)
Cx frame (speeder cycling)
Carbon bars(hylix) drop ones on cx bike
All had serious use and mileage without a single issue 🙂
Keep splashing your cash on the carbon with a pretty name on it if it makes you feel better/look cooler 😆
Posted : 12/10/2014 3:54 pm
I've been running those type of ti skewers (mine were from Taiwan).
Got a set on my road bike and on my cross bike. Had them on a few years with no issues. Raced, ridden, rough stuff roads and proper cross races.
Posted : 12/10/2014 6:11 pm
Is the widespread fear of Chinese carbon failure based on real world evidence then, or is it just that they are not reassuringly expensive with a boutique brand name printed on it?
Sudden catastrophic failure of a handlebar is potentially no worse than similar of a frame or fork, and threads on Chinese carbon frames always get replies from people happy with them.
I wasn't sure about the wisdom of using titanium for skewers anyway, regardless of the manufacturer, so for the minimal weight saving, I think I'll stick with steel.
Posted : 12/10/2014 6:14 pm
 JCL
700mm? Great for midgets and kids I guess.
Posted : 12/10/2014 6:26 pm
Not enduro enough for youjcl 😉
Posted : 12/10/2014 6:37 pm
Presumably that's the handles? Aluminum skewers would be pretty scary!
I had a pair of cheap (AEST?) skewers, they came with plastic cup washers rather than brass which deforemd as soon as you tightened the QR, so they got binned.
Bought KCNC ones from XCracer and they've been fine, apparently the Mt Zoom ones at half the price are even better but at the time i just wanted some good ones that worked so opted for the most expensive rather than risking it again.
By some and report back!
Posted : 12/10/2014 6:41 pm
It will be a bot of both
Its an unknown leap in the dark
they could be he same as a boutique brand from the same machines or they could be made as cheap as can be in some backwoods factory with no QC
If i was to to do this I would use a big well know manufacturer or supplier of carbon parts for peanuts. That is not that supplier from what I can see
Posted : 12/10/2014 6:51 pm
All I ever use on my road bike is Chinese carbon and I am still alive. Frames, bars, stems and seatposts all without bursting into flames.
Posted : 12/10/2014 6:53 pm
I had those skewers, binned them and went back to Shimano. Weak clamping force and mine had a cheap plastic bushing thing that fell to pieces.
Posted : 12/10/2014 7:06 pm
That's the problem isn't it?
My inherent racial stereotyping tells me that any Chinese factory owner who makes components for the big name brands would have no moral objection to making a few extra without the logo and selling them on the cheap.
Unfortunately, I suspect they would also have no objection to making another batch using poor quality materials that look superficially identical and selling them cheap too.
How do I know which is which?
 JCL
Yeah even 740mm feels tiny to me.
Posted : 12/10/2014 7:18 pm
You're just #SoEnduro, as you seem desperate to keep pointing out.
I hope you paint your 1100mm bars fluoro yellow for extra #Enduro points?
The best lightweight skewers I've tried were either Tune AC16/17 or Mt Zoom. The Tune ones have a proper internal cam, but they're bloody expensive. The levers on the KCNCs were too short IMO, the Mt Zoom ones work very well.
Posted : 12/10/2014 7:22 pm
Last 2 years of XC racing on unbranded Chinese carbon bars now, first year mostly rigid, then hardtail. Prior to that was using Easton carbon monkey bars, they cracked.
Chinese ones have not exploded and I'm still here posting about it
Posted : 12/10/2014 7:27 pm
Amedias, which brand of unbranded bars?
Posted : 12/10/2014 7:29 pm
Can't remember, bought on eBay with some skepticism but I have as much faith in the as any other bar now
Posted : 12/10/2014 7:32 pm
Oh and a climax 130g weenie seatpost that's taken a beating on my local roads without snapping and rogering me 😯
Posted : 12/10/2014 7:34 pm
How wide do you want? There are loads of "Mr Ride"/Climax 660mm ones, 145g. So not crazy light, but only £40. I'm contemplating their seatposts.
Posted : 12/10/2014 7:36 pm
I have a friend who rides XC and cross at a reasonable level. Both his XC and cross bikes are generic chinese frames and his cross wheels also. He's had no issues with any of his kit.
Getting back to my chinese road frame and bars, it's handled the ripped up tarmac on alpine descents 3 years on the trot and there are some big holes coming down the HC side of the Joux Plane.
I also run a 90mm tub chinese front on my Scott Plasma, it's been a solid purchase at £150 delivered.
I don't have tons of cash to throw at exotic gear so I make it stretch where I can.
The Chinese stuff is ok but I'm still reluctant about fitting some to my Enduro as I'm not sure they'll survive a half decent off, saying that, a nice light ally pair probably wouldn't fair much better I guess.
Undecided.
Posted : 12/10/2014 7:38 pm
To the OP, I'll be interested in your views on the bars should you get them.
Posted : 12/10/2014 8:16 pm
 br
I've run an MT Zoom Ti skewer for years in the rear. Never been a problem.
Posted : 12/10/2014 8:21 pm
 JCL
No. Just with the times.
Posted : 12/10/2014 11:06 pm
Aaah, so you're a fashion victim? Presumably you're using a Yardstick bar or equivalent? What did you praise before the industry told you that wider was better?
Posted : 13/10/2014 7:12 am
Using exotic carbon bars on my Lurcher rigid, which gets a beating. No issues with instant death whatsoever.
Also took a punt on some fully built whells from chinese ebay seller CN Carbon. They're really rather good too.
AndyV
Posted : 13/10/2014 8:57 am
[i]This quick disassembling carbon fiber handlebar is easy to use,and one of the best gifts to your friends
The carbon fiber handlebar is made of high quality carbon fiber.So that you can use it relieved
With the special design,the carbon fiber handlebar can save for a long time
[/i]
Well thats me sold.
Posted : 13/10/2014 9:09 am
Well thats me sold.
Can you write convincing marketing spiel in Chinese?
Posted : 13/10/2014 10:40 am
I've got some Extralite ones which seem pretty good. I also have KCNC ones on the roadie where they're fine, but wouldn't use them on a MTB.
Posted : 13/10/2014 10:48 am
I've got some Parts of Passion ones which are obscenely expensive, but utterly useless, I'd avoid them!
Posted : 13/10/2014 10:52 am
[i]Can you write convincing marketing spiel in Chinese? [/i]
Nope, but then my day job isn't flogging stuff on ebay to the chinese.
What does [b]'quick disassembling carbon fiber handlebar '[/b] mean to you?
Posted : 13/10/2014 11:36 am
What does 'quick disassembling carbon fiber handlebar ' mean to you?
To me it means somebody made a poor translation/mistake
Posted : 13/10/2014 11:51 am
Interesting thread. I too have had a bunch of cheap unbranded bars and seatposts in my ebay watch list for weeks now, still not brave enough to try them.
Posted : 13/10/2014 11:54 am
Their £300/1320g 38mm clinchers look good!
Posted : 13/10/2014 12:01 pm
That's exactly why I bought some actually, every time the topic came up there would be lots of fear-mongering, scare stories and teeth sucking, and 2nd hand anecdotes about the postman's nan's hairdresser's husband who had a Chinese carbon bar that exploded once and sent carbon fibre shards straight to his heart and killed him and his cat dead, but very little actual 1st hand reports.
I was (and still am) very sceptical about some fo them, but I bought some cheapies off ebay (£15) and put them on just rode them as normal, nothing broke, so I started using them on my race bike, trying to do a proper 1st hand test and use them under the same conditions I would any other bar.
The bars (and me!) survived, so I kept using them. They don't seem noticeably worse finsihing wise to the other branded bars I have either.
Who knows how they will fare long term, or in terms of ultimate strength, but I've had a couple of years on them now with no drama and I pretty much forget they are there until someone asks what make they are.
There seems to be general acceptance of cheap Chinese carbon when its a frame, or rims, or even a fork, but for whatever reason there's still a lot of doubt about bars and seatposts.
Make of that what you will, but all I will say is I have noticed that in general, most of the scare-mongering comes from people who haven't used them (natural perhaps as they have doubts so aren't going to), where as most people that have used them have reported very few issues, certainly no more than any other material or brand.
Posted : 13/10/2014 12:05 pm
Page 1 / 5
