• This topic has 8 replies, 6 voices, and was last updated 7 years ago by D0NK.
Viewing 9 posts - 1 through 9 (of 9 total)
  • Changing from a 28 tooth to a 32 tooth chainring
  • oikeith
    Sorry for the simple question, I did search the internet but couldn’t find a related answer.
    Got a new bike that runs a 28tooth front sprocket and a 10-42 on the rear. I am looking to go back to a 32 on the front as I had on my old bike, will I need to add any links to the chain?
    The bikes new so I dont have any spare links for it, so if I do need to add links a new chain would be needed, which I am hoping to avoid!
    mikewsmith
    Sram I think said the 11sp could go 2t up or down without altering the chain so it really depends how it’s been trimmed.
    n0b0dy0ftheg0at
    Is that existing 28T 64BCD?
    If so, biggest ring you can replace it with is 30T, IIRC.
    32T ring would require 104BCD option of crank.
    oikeith
    n0b0dy0ftheg0at – Member
    No, sorry should have mentioned its the raceface cinch system.
    nickc
    what bike? (more specifically), what wheel size?
    oikeith
    nickc – Member
    The bike is a 2017 Specalized Enduro with the big ol wagon wheels that are 29! 🙂
    nickc
    bear in mind it will be like going from 32t to 34t on a 26″ bike.
    I’d probably fit a new chain rather than muck about with extra links if I was replacing the chain-ring, and depending on how old the cassette is, change that as well.
    andyl
    Buy a spare chain and make the correct length. Add the left over links to your old chain and alternate between them. Much better way to manage your drivetrain wear.
    D0NK
    was your old bike the same wheel size/type and running the same cassette?
    apologies if you know this already but if your old bike was a 26er and you’re now on 29+ the swap may leave you with rather tall gearing. Plenty of gear calculator apps around to check.
    If so, biggest ring you can replace it with is 30T, IIRC.I thought BCD only limited the smallest ring you could put on, bigger is fine. Sure enough manufacturers aren’t likely to make a 53t 64bcd ring but I’d have though 32/34 rings would be available.
    <edit> oh and good luck, cinch was easy to swap over but getting the cranks off was a job and a half, mrs stood on the crank arm, me stood on the long allen key, CRACK! as it undid. Maybe no grease/antiseize when fitted, dunno, worried me tho.
The topic ‘Changing from a 28 tooth to a 32 tooth chainring’ is closed to new replies.
