Viewing 40 posts - 1 through 40 (of 41 total)
  • changing from 3 rings to 2
  • nunuboogie
    thinking of changing my orange 5 to a two ring set up, what size rings do people use? Is this quite an easy change?
    TandemJeremy
    Have a search – its been debated many times. Depends on your riding style and local terrain. 22/36 for me.
    tron
    Use Sheldon Brown's gear calculator. Going to 22/36 from 22/32/42 would mean that I lose the top two gears – ie, 42:11 and whatever's next to that. Not a big issue to me.
    soobalias
    mincers go 22/36 and stretch to an 11/34 cassette
    racers go 32/44 and use a road block 12/25
    replace the outer with a bash ring (same BCD)
    or
    replace the chainring bolts with shorter ones
    thomthumb
    36/22 on one bike 36/24 on the other.
    In my opinion keeping the 22 is a must (doesn't make that much difference but when your riding up a mountsin knowing you have a 24 you need a 22 ;))
    as TJ said 36 lets you retain most of the gears. however i have noticed that the cassette jumps are more noticable on a 36T ring.
    I'd like to try the stx 36-12 cassette next time…
    njee20
    +1
    XC riding here, 28/40
    ooOOoo
    Hmmm 32/44 – 12/25 sounds fast and fun….but how do you get up steep hills?
    A granny ring weighs chuff all, so why not keep it?
    njee20
    Better chain line if you go 2×9 using inner/middle ring. IMO it weighs sod all and is no real use either!
    He was kidding about 32/44 with a 12-25, a few Dutch folk on WW are running that, but that's not really much use!
    wwaswas
    just gone 29/44 via a middleburn duo on my inbred. Seems fine and having ridden SS all winter anything lower than 32:18 seems a bonus on the hills.
    nunuboogie
    Cheers guys, would mainly be used for welsh trail centres and riding round the lakes.
    mogrim
    +1, unless you're talking about getting rid of the big ring and sticking a bashguard on.
    mttm
    Check with Orange – certainly earlier Fives had issues with the chain catching on the swingarm on 34t or 36t rings. Newer ones may be different.
    njee20
    For the exact reason I said, it weighs chuff all, but it's also sod all use, for me running a 28/40 type combo is more usable and gives a much better chain line.
    _tom_
    I'm using 22-32-bashguard. Works fine and looks so much cleaner/nicer than a 3 ring setup.
    clubber
    24/36 and 11-34 with no bashring and a double specific SLX front mech for me
    All discussed already here: http://www.singletrackworld.com/forum/topic/as-it-looks-like-i-need-some-new-chain-rings-talk-to-me-about-2×9-for-xc
    mah05
    i just use a 22/32 with bash on my 5. thats plenty for trail centres. as mentioned above i think theres problems running bigger than 32 on a 5
    IamSam
    Hey Kel,
    Just changed to 22 32 and a bash. you get all the gears you'll need for the five, plus loads of clearence.
    Works great for the lakes even for end of a ride road home sprints and the like.
    Properly glad the big rings gone 😀
    sam
    Konastoner
    24/36 & 11 – 32 for all my riding. Tough at first but you get used to it.
    cookeaa
    Just switched 22/32/bash for 22/36/bash it’s only 4 more teeth but the 36 gives a just few taller gears if you want them, stuck with a 22t granny just in case, better to have spinney gears if you need them…
    ooOOoo
    Think I'll keep my big ring then and just mash past you slow 36t people :mrgreen:
    jam-bo
    36t on an older orange five needs a spacer moving on the BB to move the chainline out a couple of mm.
    TandemJeremy
    ooOOoo – Member
    You often pedal beyond 30 mph offroad then? I don't
    Olly
    22,36,bash is all you need unless your into large sections of road smooth descending
    mathewshotbolt
    On my 5" bike i run a 22-36 chainring combo with an slx 12-28 cassette.
    in the scottish 7 stanes i never found the need for total bottom gear on long days out.
    carbon337
    Im using a 22-32-bash on my 2010 Five. With 11-32 cassette. Always been ok – only time I ran out of gears was on a big decent in the Cheviots this weekend and to be honest I didnt need to go much quicker so just didnt pedal.
    Had the bike 3 months and hadnt used the 44 ring and it was scratched from rocks so off it came for a 32t fsa bash.
    kenneththecurtain
    Highest gear on my DH bike is 36/11. Only place you get close to maxing that is on the motorway at fort bill – how many xc rides involve going anywhere near that fast?
    njee20
    Off the start line at Sherwood and Thetford I'd rather have higher than 36/11.
    It's not so much that the 36 isn't enough, just that I find with a 40 I spend more of my time in the middle of the block, rather than right at the bottom. I also find myself using the 40/11 on the road to the trails.
    MrCrushrider
    22/36 for me – any smaller middle ring leaves me spinning too often
    CaptainMainwaring
    +1 for 22/36 and 11/34 cassette. If you ever come to Scotland you will realise why you need the 22 and 34
    ooOOoo
    What's the cog 3rd off the top? I'm normally in that and 44 on the front on the commuter HT (yeah it's a flat 4 miles). I'm often there off road too on anything vaguely downhill. I'll get into the top cog occasionaly if gunning it on a long downhill.
    I'm up for trying a 2×10 bike at some point, but I get the impression it's more for spinners. I think like my dad I'm naturally a slow rpm pedaller.
    njee20
    Depends on the ratios, the 28/42 with an 11-36 replicates most of the gears on a conventional triple frankly! Your top gear becomes somewhere between the very top, and one cog up the block. Check Sheldon to work out gear inches on the different combinations.
    TandemJeremy
    ooOOoo – Member
    a tiny bit lower than top with a 36 chainring
    clubber
    Doesn't mean you can't train yourself to spin – I did and it made a big difference for longer rides.
    molgrips
    I used to use 29/42 on my Pace with a Middleburn duo. I loved it – only lost the bottom two rings, but the bike was a good climber anyway so I dealt with it. I also had 22/32/bash on my first Patriot, and it was well annoying on pedally downs – I'd only do that again on a bike I knew wasn't going to be ridden much XC.
    bikerbruce
    im riding a 39-28 set up with a 11-34 cassette and it's great
    soobalias
    3rd from top? probably 14t.
    as TJ says check the Gi on 36/11 and 44/14.
    nunuboogie
    Been in-touch with Orange, chain may catch on the swing arm with 22:36, but should be ok with 22:34.
    nunuboogie
    Hi Sam, cheers just what i needed to hear 🙂
    we are planning a ride with Ju sat morning if you are around?
    IamSam
    Hey kel,
    didn't know you were up this end of the country. Its a possibility but am ment to be picking up a shed for the allotment and laying some flags as payment for it……………….. You riding round there neck of the woods? Really want to check out crag quarry flew over it the other week and it looks interesting.
    nunuboogie
    Think we are riding crag quarry sat? If that's the new bit on the top?
The topic ‘changing from 3 rings to 2’ is closed to new replies.
