Very almost – when we moved in there was a gas pipe in place for a coal effect stove in the fireplace, just the rest of it was never installed… so we had the same stuff to deal with.
We got a proper gas fitter bloke to come in and deal with it all (he is both gas and solid fuel qualified, if you are in North Lancashire/South Cumbria…). He lifted the carpet and floorboards to remove the gas pipe (it was live), put a new slate hearth down, opened up the fireplace to suit the woodburner I had bought, lined the chimney (it had a gas flue in that was big enough to drop a 6" solid fuel liner down the inside), replaced the chimney pot with a solid fuel one (rather than the metal gas flue end piece) then fitted the stove in properly.
Cost a fair bit (think it was a bit over a grand) including the liner, slate hearth, rendering the new fire opening, replastering the wall above. But all done properly and it took the best part of a day.
Well worth going for!
