Chains (pin to pin ...
[Closed] Chains (pin to pin length rather than width)
[#1667347]
I am just in the process of doing up a bike and making it single speed, an old tourer for commuting - not mtb. I bought a singlespeed freewheel (18t) from Condor Cycles - the cheap one for a tenner. Having put it on the chain just doesn't seem to fit on the cog. I have tried the original chain (it was the original off an old 80's 10 speed Falcon). I have also tried a SRAM one I had kicking around but that is the same. It's as if the spacing between the pins on the chain is too long - it can't have stretched that much and the SRAM one was new so had no stretch? I have checked Sheldon Brown but he doesn't mention different chain types (pin to pin length rather than width). Are there different sizes or am I being being dim, or both? Ta.
Posted : 02/06/2010 8:29 pm
Pics?
Seems odd that a new chain does not fit. Inconceivable (unless it is the width)
Posted : 02/06/2010 8:36 pm
I think there was once some track kit with 10mm pitch but I doubt you've come across any of that. Otherwise, it's all half inch (unless it's very very worn)
Posted : 02/06/2010 8:39 pm
width is fine. I'll try and get pics now.
Pitch, that's the word I was looking for. I'll measure.
Posted : 02/06/2010 8:41 pm
ok, I'm being dim. Width of the inner links is the problem. Back to the shops...
Posted : 02/06/2010 8:53 pm
YES!!!!!!!!!
*punches air*
Posted : 02/06/2010 8:57 pm
pint of ale to the man with his fist in the air
Posted : 02/06/2010 9:00 pm
