Viewing 9 posts - 1 through 9 (of 9 total)
  • chainring, single ring, chainguide… i'm missing something…?
  • weeksy
    So today i thought i’d fit my Superstar Chainguide…
    http://superstar.tibolts.co.uk/product_reviews_info.php?products_id=475&reviews_id=1427
    After about 20 mins and having cut my chain and removed my front mech, i worked out pretty much how it’s going to fit etc…
    However that’s where it went all wrong.
    I’ve been running 2×10 with an E-13 bash. But i can’t run the bash now as it’s too deep so catches the new chainguide. So, i remove the bashring… This is the problem bit. Chainring bolts etc.
    If i use the standard chainring bolts (from 3×10) then with the outer ring missing, i can’t get it to fit right as the base of the nut is too long and sticks out too far. Meaning i can’t tighten the bolts up enough. If i run my ones from my 2×10, that still gives the same issue.
    I assume i need smaller chainring cups/backs ?
    Lastly, the Deore chainset looks rubbish with the outer removed and nothing else there (the E-13 looks fine) so i may even end up going 1×10 with just the shifter and cabling removed… although there seems to be little point doing that, if i’ve got to leave the mech on there, i may as well fit a cable and the shifter. (But i don’t wanna do this really).
    So… what do i do etc guys?
    soobalias
    buy a few short chainring bolts?
    find a bash that doesnt foul the chainguide
    weeksy
    it’s not the bolts… it’s the bits they bolt into.
    I don’t need the bash if running a single ring.
    steezysix
    Go to a hardware shop and buy a bunch of washers that will fit over the chainring bolts and allow you to space it out (they’ll take the place of the outer ring.). This is the cheap option. Alternatively, buy new (short) bolts and nuts.
    schmiken
    Singlespeed chainring bolts required.
    xiphon
    Those guides don’t use a bash, just the single ring on it’s own (with shorter single chainring bolts, to compensate for the lack of outer ring)
    HermanShake
    Yep, or go alloy for teh grammage damage.
    weeksy
    Ordered. I can see me needing a new prettier middle ring too lol.
    Thanks guys.
The topic ‘chainring, single ring, chainguide… i'm missing something…?’ is closed to new replies.
