Click here.
The upper window shows a 26″ x 2.1 wheel bike with the normal 22/32/44 triple and 11-34 cassette. Each cog is shown against each ring on the triple crankset. For a given cadence (90rpm) each gear is shown with its mph figure below.
In the lower window, I’ve set up the same 26″ wheel with 1 x 10 using an 11-36t cassette and a 32t chainring. You can see that the 36t (easiest) ring on the cassette will give you just over 6mph at 90rpm. Compare that to the tripe setup in the upper window and you see you’re losing the three lowest gears on the granny ring (22-26, 22-30 and 22-34). You’re also going to spin out earlier (21mph) on the 1×10 setup as you lose two whole gears (44-13 and 44-11) on the triple.
You can click on each window and chainge the settings for that window below. The trick is to drag the single chainring left and right until you achieve a balance between losing lower gears that get you up the hills and losing upper ratios that leave you spinning out earlier.
Cheers,
Ian
