• This topic has 11 replies, 11 voices, and was last updated 10 years ago by hora.
Viewing 12 posts - 1 through 12 (of 12 total)
  • Chain stretch question
  • andrewh
    I have a very stretched chain (daylight between it and the rings) and no chain checker.
    Will my SRAM powerlink have stretched just as much or is this made of stronger stuff?
    Rorschach
    Chains (side plates) don’t stretch.
    Pins and rollers wear.
    andrewh
    Makes sense. That’s a no then, so that’s good, I can reuse it.
    Thanks.
    steve_b77
    If it’s a 10spd you can’t
    tom200
    Get a KMC one then you will be able to.
    JoeG
    The quicklink pins would probably wear just a much as the ones on the chain…
    New chain, new quicklink.
    damascus
    Your not supposed to reuse them but whats the worst that will happening?
    it might snap under pressure, rip your rear Mech off, go into your spokes, damage your wheel and rear chain stays.
    If your chain is that stretched you have had your moneys worth.
    How much are they? £3?
    fivespot
    your power link will be just as worn as the rest of your chain, bin it. Anyway, SRAM chains come with new links.
    Contrary to what some folk will tell you, SRAM power links can be reused many many times. mine get split nearly every week to clean the chain, and they click back together like they were new.
    edlong
    What Rorschach said above: They don’t stretch, they wear.
    wolfenstein
    Reusing powerlinks all the time too, no problem.. But yah.. New chain, new links.
    mikewsmith
    yep SRAM ones can be popped out the splitting pliers help
    hora
    Wow I bin my chain when it starts making a cracking noise/slipping. Powerlinks are used FOREVER.
    I bumped into a lad whose rear mech went into his rear wheel on a climb on his newish bike. I wonder how many of us hard-shift chains/mechs?
    I’d rather hop off- shift/spin into gear first.
The topic ‘Chain stretch question’ is closed to new replies.
