Chain slippage - ad...
[Closed] Chain slippage - advice required
[#1424545]
I could do with some advice please, i have a problem with my chain. When i am in a gear usually middle of cassette to bottom the chain slips occasionally especially when i put bit of power into the pedals. It is not when i change gear and i generally set my self up in the right gear if i am starting on a climb etc. Also i rotate two chains normally and clean them after each ride and then re-lube them when i put them back on the bike.
Any ideas???
Posted : 18/03/2010 7:11 pm
worn cassette
or worn chains
or most likely both
Posted : 18/03/2010 7:14 pm
 ojom
Hey big guy
Your mech hanger straight?
Or like SFB says.
Posted : 18/03/2010 7:15 pm
Evening Mrs.
Should add, chain measuring well under 0.75% wear
Posted : 18/03/2010 7:24 pm
Somminks worn 🙂 prob cassette even if it looks OK IME 🙂 CRC for PG990 cassettes for £45 🙂
Posted : 18/03/2010 7:36 pm
did you replace chain & not cassette ?
worn cassette & unworn chain would do that nicely wouldn't it/they ?
I had exactly the same problem this week. In the end, after the usual grumbling and tool throwing I changed to a new cassette and the problem was solved.
Posted : 18/03/2010 8:00 pm
Well thanks everyone it's looking pretty obvious what i need to do 😕
Posted : 18/03/2010 8:49 pm
looks like somebodys sold you a ropey old bike 😉
seriously though, are you sure its slipping on the cassette? sometimes it can be a worn middle ring and it just feels like the slip comes from the back
Posted : 18/03/2010 11:24 pm
