I’ve got fed up of using chain cleaners – they just make a huge mess.
No I just use a KMC power link, 1 litre squash bottle and some petrol. Works far better and doesn’t result in mesh everywhere
Same issue and same solution here, except that I use diesel. It evaporates after a while so minimal residue, and since it’s petroleum based it won’t affect whatever chain lube you use anyway – in contrast to other degreasers that you really don’t want to have left in your links when applying new oil.
Just drop the entire chain into the bottle, give it a good shake and leave it for a good while (ideally you’ll have at least two chains to alter between – just leave one in there until the next switch). Of course you can reuse the diesel/petrol forever so it’s a one time cost too. Just run it through a coffee filter once in awhile to get rid of the guck.
Most of the time though, a wipe, some new chain lube left over night and then another wipe before the next ride to get rid of the excess is enough.
