- This topic has 128 replies, 45 voices, and was last updated 14 years ago by BIGMAN.
CCDB/Decent rear shocks, how many of you use one on a 'trail' bike?
SpokesCyclesFree Member
Have to say, for me weight is a limiting factor. My AM bike is 32lbs with a DHX 3 (which I must admit isn't great) and am really keen to swap for an RP23 in order to lop an extra half pound of weight off as well as improve performance.
If a coil could get down to air weight, I would, but as it is they're too weighty. I don't want my 32lb bike to weigh even more than that.
si-wilsonFree MemberI really do have to disagree. Why should the suspension on a 3k bike not be as good as it can be? Weight is the only reason I can think of for not wanting a good coil, but it's a trade off worth having IMO
solamandaFree MemberWhy should the suspension on a 3k bike not be as good as it can be?
Because being overbiked is boring and sanitises trails.
SpokesCyclesFree MemberI can see it if your bike weighs sub 30lbs, but not a lot of bikes like this do, and for me air is sill the answer. Riding a bike over 30lbs all day is a real bind.
I use mine for DH (personally I'm too light and scrawny to muscle a DH bike, I just can't ride the things as fast), big mountains and trail centres and only for the proper DH would I perceive the benefits of the shock being more important than the weight on my bike.
mikey74Free MemberBecause being overbiked is boring and sanitises trails.
Depends what trails you ride and how you ride them.
si-wilsonFree MemberMy bike still has the same 5" travel, it just works better 🙂 so to make trails more fun you prefer parts that don't work as well as they should?
solamandaFree MemberI prefer a bike with a front bias for grip for riding xc. DH bike is different.
NotterFree MemberA fork is a tranferable upgrade should you change your frame, an upgraded shock probably won't be due to different eye to eye / stroke etc. That's probably why it's not considered as much IMO even if it is logical.
Get your point though, now is there a CCDB for a 2006 Enduro? 🙂
DirtynapFree MemberThe CCDB is the best shock out there and if you have the money then there is no reason not to get one, end of discussion.
If you can't really afford one then get an RC4.
BIGMANFree MemberI would disagree with the previous statement… The Stoy and the CCDB are probably of the same standard. The BOS Stoy though is a mich smoother shock…
It also comes valved for each bike unlike the CCDB! So for most people who can not get there head around HS and LS adjusters its probably a more useable unit!!
I am waiting for an Elka to arrive at the moment and am keen to see how it compares with the other 2 units. Like the BOS the Elka is valved for specific frames.
Reviews coming in from Canada are showing good performance comparable to a CCDb and Stoy for a lower price….
si-wilsonFree MemberI agree, it's hard to say the CCDB is the best out there, however, shocks like the Elka and Stoy require that you know what you want from your shock when you order it, once it is set it is more difficult (though not impossible) to change the settings, unlike the CCDB. So even though the CCDB may seem confusing, once you start to use it and understand the principals of each setting it can be easier to tune to your preferences on the fly.
I really want to get my hands on an Elka, once i understand a little more about what my frame and my riding style likes.
geetee1972Free MemberYep am also running a CCDB:
This bike weighs in at 30.5lbs and switching to an RP23 would save around 400g. It might be worthwhile but I doubt it. The performance of the CCDB is just too good.
Si – your comments mirror my experience, which is that there is a true separation of high and low speed compression. I've always found on most air dampers, that the low speed compression works to inhibit the movement of the initial part of the shock stroke. This then gives a firm platform that reduces pedal/rider induced bob, but it also inhibits compliance over smaller hits and therefore reduces grip.
With the CCDB, I have probably about 50% of the LSC wound on; the bike is super stable, has zereo bob and can be pumped through the trail no problem. But even over the smallest of bumps, which shoud still be 'high speed' compression events, the the damper responds and gives amazing levels of grip.
The point about the CCDB not being custom shimmed is true but it's beccause it doesn't need it. The range of adjustment is so large that it doesn't need to be custom shimmed.
sam-rFree Membersolamanda[quote]Why should the suspension on a 3k bike not be as good as it can be?
Because being overbiked is boring and sanitises trails[/quote]I don't think you can mean deliberately detuning/not optimising suspension set up in order to have more of a challenge, but that is how this reads…
brantFree MemberOdd then that Jones didn't seem to get on with it too well this month in Dirt, on a Chumba.
The Socom that nearly killed me had a CCDB on I think 🙂
dasnutFree Memberllandegla isn't exactly a real test for a rear shock is it?
I could go round there on my bmx 😉£700 for a trail centre shock? there is a touch of the car salesman about this thread…
for only £300 more, you can have all this extra. The more you spend, the more you save, the faster you will be…..
BIGMANFree MemberYeh the CCDB is good but wont work on all bikes!!! And having a shock valved for the bike means you get an amazing base set up….
If you want a smooth shock which tracks and uses its travel without blowing through the Stoy is an amazing shock!!!
It can also be serviced in the UK.
The CC can not be unless you trust Stendec! The lack of UK service centre is the reaon I will not use a CC anymore….
si-wilsonFree MemberIt is odd that Jones didn't like the CCDB on the F5, Richard from Gravity Sports, who sent the F5 over for test, rode it with the Fox RC4 and CCDB and prefered the CCDB, Dunacn Riffle who rode the F5 in world cups last year prefered the Vivid, opinions eh?
geetee1972Free MemberOdd then that Jones didn't seem to get on with it too well this month in Dirt, on a Chumba.
I think it just proves the notion that there is no such thing as an absolute.
si-wilsonFree Member£700 for a trail centre shock?
Not sure i get your point? Does that go for other expensive parts for trail centres?
One of my points is, people will spend £400 on wheels, £400-£700 on forks, £100 on a carbon bar and then scrimp on the most important part of any full suspension bike, doesn't make sense, regardless of what surface or where you ride.
BIGMANFree MemberFor some reason from what I was told the hydraulic dampening on the high end shock gave a weirg feeling to the back end…
They thought it could benefit from a more traditional shock as that is what the linkage was concieved around!
julianwilsonFree MemberWhat a lightning-fast customer service response it was that just 2 weeks ago someone started this thread, and now according to the story on the front page, you can already get a great deal on CCDB upgrades on Chumba frame kits…….. oh.
IGMC.
doof_doofFree MemberGenerally CCDB's are a 'one size fits all' solution, meaning they have a very wide range of adjustability to cover all linkage rates, etc. Just have a look on MTBR to see how much confusion that CCDB set up causes many (most?) people.
I personally prefer Avalanches approach of a 100% custom valve shocked assembled and tuned for the rider, terrain and bike. The external adjustments are then only for fine tuning. MUCH better IMO. The Avalanch can be rebuilt by any competant MX shop (as it uses MX seals), can be re-tuned should you change bike (even change eye-to-eye length). The customer service from Craig (owner) is second to none.
Again, plenty of animated debate on CCDB vs custom Avy's, but my money went with Avy with no regrets.
For those that are interested:
HoratioHufnagelFree Member"Damping" seems to be one of those mysterious black arts.
Theres almost no concrete information available from manufacturers, my Rockshox fork came with no instructions for the blackbox motion control setup. I think this leads to lots of confusion and mis-information on the mtb forums. Its no good just the high-end manufacturers supplying the data either because if you don't know how your current shock works how do you justify the upgrade.
What happened to the 5th element shocks too, weren't they supposed to be the latest and greatest?
z1ppyFull Memberhmmm this has thrown the cat amoungst the pigeons for me.. quite fancy a CCDB or even a Stoy, but damn their expensive, when my whole bike only cost 750 (2nd hand, admittedly 2k+ when new)….
Bigman where are you getting your Elka from?
If direct from Canada, how do you plan to get it serviced?Think it may just be a RP23 in the end, much better than my std 3way Manitou POS (got a RP23 on loan)
the_lecht_rocksFull Memberi like my CCDB although baulk at the weight penalty.
with a spring change and alternate damping settings it can change my helius from a trail centric biased bike into a rock munching DH'esque machine.
there's a vast array and span of adjustment, and , tbh, enough opportunity to really mess up the ride, but what suits one rider doesn't suit the next.
i like my helius taut and zippy on XC style runs and soft and forgiving over rock / DH.
the frame can take it, and the shock is adaptable. makes perfect sense in my book, as does ensuring whatever shock you ride is as good as you need it to be.
of course, there's the price issue, but it's all relative, innit ?BIGMANFree MemberElka are now distributed by Silverfish! They have technician in house who has been trained to service them in house!!!
There also 450rrp iirc?
Mine was bought from Biketart. adam@biketart.com
I am keen to see how it compares against the Stoy… The BOS is an amazing shock….
The shock is here and the mounting hardware is currently being shipped! I will report back once i have had some time on the shock… Doing 3 days of shuttles next week so should be able to dial it in during that period…
If you have a look on a website called rotorburn there is a review on the BOS, Elka and CCDB..
They have actually compared all the shocks and mention in which way they find each is better… Am I aloud to post a link to it on here???
SBrockFree Memberthis weight issue people have with a Coil Shock really irritates me!!
FFS get a grip of yoursleves!
I have been running an low-compression (OE from SC) RP23 on my Heckler – The way those shocks have been tuned by Fox for SC SUCK!
Upgraded to a Fox Van R Coil, then Ghetto'd tubeless my Tyres and it pedals/grips/descends soo much better than the RP23.
Weight????? I can't tell that it makes any difference whatsoever –
All this fuss about 'coil shocks are too heavy' is total bollocks.
mjroseFree MemberSlight thread diversion here but, i found that swoping from DU bushes to needle roller bearings on my RP23 made a massive difference to small bump sensitivity on my Blur LT.
Slightly cheaper upgrade than a CCDB too……
DirtynapFree MemberI agree the stoy is a great shock, forgot about it actually. Never used an avalanche but seems there pretty nice also.
400 grams extra weight over an RP23, thats funny to me. Why care?
AristotleFree MemberMost people I know don't seem to bother, but setting up your suspension (existing or upgraded) properly can make a big difference to a vehicle.
It does takes time to get it right, but good forks/shock badly set up incorrectly won't help.
Anyway, ride a hardtail and you've only got half the suspension to worry about.
poisonspiderFree MemberI've got a CCDB on my Orange 5 and can honestly say it is a world away from the RP23 it replaced.
Better traction, small bump sensitivity, big hit capability, absence of pedal bob etc etc. Better in every respect apart from weight, which I don't notice anyway.
Yes it's expensive, yes it's heavy, but it's worth it.
Not sure about BIGMAN's comment about servicing. Stendec is listed as the UK service agent on CC's website and as far as I'm aware they are perfectly capable of servicing it. Why shouldn't I trust Stendec??
Having said all that, in support of the view that forks are more important than rear shox;
Which would you notice the biggest improvement (for general trail riding that most people do) fully rigid to hardtail or hardtail to full sus?
I'd say fully rigid to hardtail – that's why most people see forks as being more important and therefore spend more money on them.
BIGMANFree MemberAfter what the retards did to mine I would not trust them to fix an puncture never mind a shock!
The shock was not bled correctly which in turn caused the shocks compression to go wrong. Royaly buggered it. Called Stendec and they were less than helpful. Send it back and we'll look at it. 2 week turnaround and I may be charged!
Called CC and advised of problem! They apologised about Stendec. Said there aware there is a problem there and asked me to return the shock and they would fix it FOC…
Awesome by Cane Creek but i was without a shock for 4 weeks… Not ideal!
Hence I always buy a product that can be sorted in the UK quickly!!
mildredFull MemberJust going back to what mjrose said above, on air shocks, swapping bushings and mounting hardware does have a massive effect on small bump sensitivity, as does compression tune. E.g. I bought a basic Float R for my Nicolai helus FR and it was terrible (though better than the Monarch originally fitted). It took an age to settle into its sag point and just felt wooden.
I sent it back to Mojo who valved it for my bike and played around with bushes and mounting hardware and the transformation was unreal. I don't think it could've been better. this surprised me so much that in an effort to find out why I eventually spoke with Kalle Nicolai who explained that the helius platform is designed to work with a very basic shock with minimal compression damping/platform damping (something to do with levers). I also spoke with TFT who agreed with this but recommended an RP23 so it gives you something to play with settings wise. It was interesting to note that nobody suggested the DHx at any point.
So, back to what Jones said about the CCDB on the Chumba, i understand where he's coming from – some bikes simply work better with more basic but custom valved shocks (I also realise that personal preference has a large part to play here).
kaminaFree MemberWhen I had a Chumba XCL I really felt the shock was blowing through it's travel (both the dhx air and the rp23 that replaced it). Pushed the rp23 and felt it worked pretty well. The Chumba was stolen and I ended up getting a Intense Tracer instead. I hated the (2010) rp23 it came with and replaced it with a pushed Van R. Even with a steel spring I did not feel the increased weight, but the performance was from another planet.
Now I'm waiting for an Uzzi VP frame, and I have an Elka in the closet which will be installed right away. Would have gotten the CCDB but the Elka ended up being cheaper then the upgrade to CCDB (so now I'll have an extra DHX 4 for backup).
As the pushed rp23's worked pretty well I would say it is possible to get an air shock to work decently, but I doubt it can work as well as a good coil shock.
edit: BTW, Push will soon be offering the MX tune again. This basically replaces most of the internals with Avalanche parts for far cheaper then purchasing a new shock. So if you have an old Fox shock you might want to wait and see before replacing it with one of these "higher end" shocks.
tinsyFree MemberWill be in the Alps on a bike worth less than one of these shocks.
When I had plenty of disposable income I still would have struggled with a purchase like that, but yeah why not if you got the cash, have the best.
Any of you ridden Foes bikes with the Carnutt shocks?
tinsyFree MemberThat might have been read like and arsey comment, but was just wondering what the Foes perfomed like againt the best money can buy setup other make bikes..
chakapingFree MemberVery interesting thread.
Kamina – Do you know if TF Tuned will be doing the MX Tune modification?
I've been reading about it this week and it does sound appealing. There was a US price of $499 though and I can't help but think that will translate to the same figure in £££s.
kaminaFree MemberKamina – Do you know if TF Tuned will be doing the MX Tune modification?
Yeah, I spoke with them a month or two ago and they said they would. They were not too optimistic that push would manage to stick with their original schedule though(I have not been following this lately as I got the Elka for a very competitive price).
The topic ‘CCDB/Decent rear shocks, how many of you use one on a 'trail' bike?’ is closed to new replies.
