From the cane creek website: “Factory Neutral: We do not currently have a Base Tune developed for this bike.”
My set-up:
25% sag
HSC: 2.5
LSC: 17
HSR: 1
LSR: 17
Took off the high speed rebound to make it pop more off jumps and lips, and put on a little extra high speed compression to keep it controlled on big landings, and propped up a bit more in corners.
Added a few extra clicks on both low speed rebound and compression just to make it climb a little better and not move around so much when out of the saddle pedalling.
The only downside is that on bigger landings (to flat) it can buck a little bit. My goals were to get it a little more playful, without compromising it over chattery small bumps, and it seems to have worked pretty well.
