Carpenters; best wa...
[Closed] Carpenters; best way of doing skirting?
[#8475260]
I'm looking to do some skirting and architrave, I'll be doing the whole house eventually so I don't mind spending some money on tools if required.
There seems to be a few schools of thought; compound mitre saw or coping?
I'm not expecting 45deg cuts, so my concern with the mitre saw is that I spend money on something which doesn't make the job any easier!
Coping is pretty neat, perhaps a bit fiddly? Or is it just the best way?
Suggestions and recommendations for tools would be great. I have seen this one which looks quite reasonable, but I'm far from expert so happy to take guidance!
https://www.amazon.co.uk/Makita-MLS100-240-255-Electric/dp/B0013UY7N2/ref=cm_cr_arp_d_product_top?ie=UTF8
Posted : 28/04/2017 9:58 pm
I'm no carpenter, merely an amateur.
Pre-primed MDF skirting if you are painting it.
Flexible to conform to walls and little prep for a perfect finish.
You need both a mitre saw for external joints and architrave and a coping saw for the internal joints. As you say rarely are joints 45 degree so you need a good eye.
Oh and use 2 part car body filler to fill, sets quick, hard and easy to sand into shape.
Posted : 28/04/2017 10:05 pm
I'm looking forward to the replies on this question, but in the mean time I can verify that's a good mitre saw should you go that way. I will add toolstation and screwfix carry the various models of makita mitre saw on next day order to store. Saves you paying postage and waiting in.
Posted : 28/04/2017 10:06 pm
For home use I'd just get a decent hand mitre saw. If your house is square then anything half decent. If you have a few wobbly walls then look for something with adjustable angles.
I did the last house with a regular hand mitre saw but only had 90 or 45 degree angles, cutting was fine but a couple of walls that weren't perfectly square needed calking up, looked fine though after finishing.
Posted : 28/04/2017 10:07 pm
 Murr
If you can buy a chop saw and a coping saw , you don't do mitres in internal corners you do scribes , start by fitting the skirting to the wall and cut them square at the end , use the chop saw to cut a 45 angle the follow the profile with the coping saw so that your left with a scribe , cut it to length make it 2/ 3 mm big for a tight fit and continue around the room .
Posted : 28/04/2017 10:11 pm
What sort of skirting board are you using? If it is something nice and simple like a bullnose profile, a powered mitre saw will give you nice smooth repeatable cuts.
Posted : 28/04/2017 10:16 pm
Hey dude, get yourself a half-decent mitre saw and drop me an email. I'll pop round one day and show you what you need to do.
Posted : 28/04/2017 10:20 pm
Trend adjustable mitre gauge great tool.
Posted : 28/04/2017 10:21 pm
Check! 145mm torus to be precise!
Thanks! Do you think it'll do OK for 145mm skirting?
Dammit!
Really?!? That's incredibly generous Darcy! Is that one I linked to "decent" enough?
Posted : 28/04/2017 10:22 pm
A decent handsaw, mitre box/guide and coping saw is all you need, save your money.
Posted : 28/04/2017 10:26 pm
Yeah, no probs man. Just let me know when you're planning on doing it. We can do a couple of hours of internal scribes, external mitres and an architrave set. You'll be flying.
The only thing I'd recommend over that Makita would be one with a slide. Going up to a slide in Makita will be another £100 or so. There's a Metabo on there with a slide for £150ish. For cutting mdf, that'll be fine. I see there's a stand with it to take total to £200ish. Metabo isn't bad kit. V popular in Germany - possibly not quite Makita or Blue Bosch, but more than enough for what you need.
Posted : 28/04/2017 10:32 pm
The tool whore in me is starting to shudder.......
Posted : 28/04/2017 10:35 pm
bookmarks. Have got this coming up as well. Another +1 for metabo but a nice bit of blue bosch always goes down well
Posted : 28/04/2017 10:39 pm
If you got the smallest bladed Makita or Blue Bosch with a slide, I think they would be perfect for your job. There's a Hitachi there as well for just over £200. Again, that'll be fine. A stand will be a lot of help as well - one of those things you'd be wondering if you really needed and then when you've had a day arsing about with trestles, you'd be crying out for one.
Posted : 28/04/2017 10:40 pm
Do I need a coping saw too darcy?
Posted : 28/04/2017 10:43 pm
...we've only just begun...tra-la-la
Posted : 28/04/2017 10:45 pm
Sometimes you just want a like button so bad.
Posted : 28/04/2017 10:46 pm
He's just jealous wrecker. 🙂
Posted : 28/04/2017 10:49 pm
😳 I just want to be ... close to you, deadles !
Posted : 28/04/2017 10:52 pm
There's a lot of wood being got here. 😮
Posted : 28/04/2017 10:53 pm
AHEM! What am I, chopped liver?
Posted : 28/04/2017 10:55 pm
A mate was once at a pub quiz where the winning entry in the prize draw - "what's the difference between Cliff Richard and a tennis ball?" was
You can't chop Cliff Richard in half, fill him with warm chopped liver and **** yourself off
anyway, you know I can't last a day without you, wrecker
Posted : 28/04/2017 11:06 pm
Whilst I like this comment, I must challenge it. I bet you could.
Posted : 28/04/2017 11:19 pm
