Carbon seatpost gre...
[Closed] Carbon seatpost greasing
[#912339]
Hi all, i`ve just spent my hard earned money on a easton carbon seatpost. Do i grease the post like the alloy ones ? I dont want to ruin it do i !!!
Posted : 01/10/2009 8:26 am
Don't use normal grease, it could cause the carbon to expand and get stuck in the frame. Insert 'dry' or get some carbon specific stuff.
Posted : 01/10/2009 8:32 am
talcum powder
Posted : 01/10/2009 8:34 am
carbon assembly paste is what you want. Also helps it "grip" so your don't need monster torque to hold it in place
Posted : 01/10/2009 8:45 am
 juan
what onza said. Grease as some micro balls inside to prevent the seatpost from slipping.
Posted : 01/10/2009 8:48 am
Yep, Tacx Dynamic Paste or sommat, or Finish Line Fibre Grip are both excellent, do not use normal grease, and actually until a year or so ago the assembly pastes didn't exist, so one just put seatposts in dry, I never had any problems!
Posted : 01/10/2009 9:09 am
I have used Finih line fibre grip but is very gritty and marks the carbon finish. Previously I just used talcum powder and to be honest works just as well and doesn't damage the finish.
Posted : 01/10/2009 9:24 am
I never knew about the talcum powder thing. Interesting. I love the smell of talc 🙂
Posted : 01/10/2009 12:48 pm
Mmmm, my seat post smells like granny used to....
Posted : 01/10/2009 1:13 pm
I used normal grease no problem... wont talc go manky if water gets in there?
Posted : 01/10/2009 1:17 pm
"wont talc go manky if water gets in there?"
well, that explains why my gran smelt funny.
Posted : 01/10/2009 1:19 pm
Posted : 01/10/2009 1:21 pm
LBS recommended Talc and that's what I use on both Aluminium frame/Carbon post and Carbon/Carbon without issue.
Posted : 01/10/2009 2:19 pm
Even Specialized say you can use talc to increase friction between carbon surfaces. Less than a quid a tub, lasts ages, smells good and is good for tyres and tubes as well.
Posted : 01/10/2009 2:36 pm
thanks for that i`ll be using er in doors talk then!! wont it fall straight off.........
Posted : 02/10/2009 8:21 am
