Hope floating rotor...
[Closed] Hope floating rotors on Avid Juicy 7's - advice needed
[#912355]
Hi All,
Just after a little advice before i go ordering a load of bits that won't work!
I am planning to run hope floating rotors on my Juicy 7's, are there any issues with doing this. I understand the rivets on the floating rotors can rub if your not careful.
I am going to use a hope adaptor to run a 183mm rotor on the front (currently 160mm post mount) and a 160mm on the rear which is a direct replacement.
Thanks in advance
Posted : 01/10/2009 8:34 am
they work fine until pad gets really worn, then there can be clearance issues - watch out for the tabs on the pads
Posted : 01/10/2009 8:55 am
Thanks fall guy, thats good news... so the issues with having to file callipers etc aren't true!
Posted : 01/10/2009 9:45 am
no using hop efloating with juicy 3 and 7 without issue.
Also swap all my wheels around so have used Avid , Hope and Shimano brakes with all /each others brands of rotors without issue.
Posted : 01/10/2009 9:50 am
When I have used discs from different systems with my Avids I checked the disc thickness and then did a bit of tuning of the pad/caliper position with some washers under the caliper mounts.
Posted : 01/10/2009 9:51 am
I had to file one side of the mounting points of the calipers when i ran juciy 5's with 183 rotors (both front and rear). I also cut the tabs off the pads as i found that they hit the rivits before the pads had worn to half way.
Posted : 01/10/2009 10:16 am
Splendid, great advice, cheers guys...
Shorts
Posted : 01/10/2009 2:12 pm
