righty, i have acquired a fizik gobi carbon railed seat (jesus this thing is crazy light).....however i cant get it to fit in the seat rail holders, as it has the tape wrapped around it obviously thickens the diameter of the rails.....its on a x fusion hilo seatpost, the normal gobi goes on fine, so its defo not me being a retard....question is do i have to leave that tape/wrap on the rails for safety reasons? or can i remove that as then the carbon rails will be the same size as the normal gobi kium rails?
Bike Forum
carbon railed fizik gobi problem?
Posted 3 months ago #
I'd leave it. Usually you need a different sized clamp to fit a carbon railed saddle to a seatpost. Most seatpost manufacturers sell them separately, I dont know whether X fusion do?
Alterantively, take a file to the current clamp.
Posted 3 months ago # -
No problem with a thomson seatpost on mine....
Evening..
Carbon railed saddles, usually only work with seatposts that clamp "top-to-bottom" much like a Thomson.I believe that your 'x fusion hilo seatpost' clamps from the side? which means that the curve in the metal where the rails sit is not big enough!
I know with seatposts like the S-Works (Has a similar clamp design) you can get spare clamps that will then take a carbon rail. Maybe worth an email to X Fusion?As for the other question.. Nope don't take the tape off. Thats the braided part of the rail, and the bit that stops it snapping!
Josh.
Reply
You must log in to post.
