try soaking it overnight in Coke (coca cola- not drugs!) if it sits in this fluid- then the corrosive nature of the drink may eat away at the seized crap. If this does not work, cut the seat post head off- leaving 30mm stuck out the top of the frame- then cut 2 slots into the seat post inner diameter- going down the depth of the stuck seat post, approx 5 mm apart from each other. The slots should be 85-90% of the way through the the wall thickness. Then tap this 5mm slot out with a chisel (carefully). Then crush the 30mm sticking out which should allow the stuck section to come away from the seat tube of the frame, twist and pull! Takes an hour or so!
