and keep the aluminium alloy for the bar, stem, seatpost, rims and cranks, but what do I know?
Not singling you out, but I’m going to bite… why? Carbon seatposts are just about the norm these days on top end bikes. Plenty of advantages to carbon rims too, although I don’t see the point in carbon clinchers really.
Why cranks? It’s more a function of which brand you go for after all. Shimano or Rotor will be alu, virtually everything else will be carbon, why would carbon be inferior?
The pro analogy falls down due to the weight limit I mentioned on the other thread, plus their different requirements, different properties in crashes etc.
I do agree on stems, as I said above, having had several they’re just a bit pointless, either marginally heavier than alu and no stiffer (Ritchey WCS), or stiffer, but far far heavier (Bontrager XXX Lite etc).
