Because it goes against every piece of advice I’ve heard 🙂
You can create a setup prone to either huge oversteer (FWD – winters on front) or massive under steer (RWD – winters on rear). not what u want when the weather is at its worst.
If you think about it, you’ll grip with one end and slide with the other. It’s startling just how much additional grip winter tyres give, and will easily out drive the summers level of grip.
If something did go wrong, I’d guess your insurers would be less than understanding. I put four winters on mine, and still had to argue against a charge for non standard equipment.
