We have a 2007 Mazda 3 and I have just swapped out the battery now it occasionally (ie once or twice over 30 minutes) cuts out for no real reason.
When I watch the revs I can see the dial hovering around 400/700 rpm, going up and down in around 100rpm increments before stalling. On other occasions it sits happily at 1200 (from cold) or 900 when warm.
I have read a few things online about leaving it running for x minutes then doing y (such as leave it for 15 minutes on idle or 2 minutes on idle then switch on air con and then leave for another 2 minutes). Other Googles suggest I need to do a manual clean out the throttle assembly or just leave it as it will settle down when the computer relearns itself (it has been about 3 weeks now so it doesn’t appear to be settling down).
Has anyone got any other ideas/suggestions etc. Thank you.
