So the flexi hose between the MAF (Mass air flow-meter) and the inlet manifold has split (perished rubber). What effect would this have had on fuel economy and power?
Im guessing that it would be under fuelling so down on power, as there is un-metered air getting into the system?
More importantly fuel economy seemed to be down recently.
I’ve fixed the problem with duck tape for now, used it to seal the ribbed bit from rogue air, so it should all be going through the airbox (and hence MAF) again.
Its a Mazda 323, not that its really relevant.
TIA
