Car Advice –Work Re...
[Closed] Car Advice –Work Related Help Needed
[#3973589]
I currently have no need to access a car for work.
This is something that may very well change in the near future.
We currently have a 2007 plate Honda Civic diesel as our only car – 40k on the clock.
It is likely that the work requirement will be a minimum of 300 miles a week up to 500 miles.
It is expected that 60% of the fuel cost will need to come from me as it will be a commute rather than business miles.
Now do I take the hit and use our Civic and just put up with the high(ish) costs to maintain it or look to buy a cheaper car?
I get 56MPG on a consistent basis but the running costs are I guess going to be higher than a Citreon C1* for example.
A low mileage C1* can be picked up for about £4k around these parts.
Do I look to go even cheaper into banger territory?
Sadly a lease scheme or similar isn’t available 🙁
Any help and or thoughts would be much appreciated.
* Only used as an example of a car I know to be reliable and economical
Posted : 14/05/2012 2:09 pm
the honda will outlast the c1 in terms of build quality esp once the miles start piling on
look after it it will look after you.
a c1 will not be economic when your ringing the neck off it to get it to keep up with traffic.
running 1 good car and changing it when needs be is cheaper than running 2 just to save the civic for best .....
and 56mpg is a good MPG tbh - at a complete guess youd need to double the mpg to make it worth while selling up and moving on - better the devil you know n all that - can always reevaluate the needs when the hondas needing replaced.
Posted : 14/05/2012 2:14 pm
