OK, so crown race on new fork, new fork on bike.
Re-attach old cantilever brakes, line pad up with rim, check return action and … pop, the spring on the left hand fork has popped out of the little hole on the tab next to the brake stud that fork it goes in.
Try again, same thing. And again. Don’t want to keep trying because every time it pops out the spring scratches the tab with he hole in.
The forks are Surly Big Dummies. Brakes are old Shimano Acera x (c.1997) which worked fine on the previous forks and work fine on the back. They weren’t used much despite their age, before I got the bike. There is only one hole for the spring, not the traditional 3. The single hole is the ‘middle’ position if there were 3.
Basically, with the brake arm on the brake stud and the allen bolt fully tightened to hold it on, the bit of the spring that sticks out to go in the hole spring isn’t long enough to stay in there.
The other side is fine – I notice that bits that stick out of the spring to go into the holes on the left hand arm are shorter than the spring on the right, and the springs are seemingly a different colour – the longer one on the right is more a gold colour, while the shorter left hand one is silver.
This is the same on the back brake – one shorter than the other – though that’s never been a problem.
What to do!?
Tempted to buy an Avid Shorty / similar, but would like to keep re-using the old components as much as possible – that’s kind of the point of this particular bike.
Cheers!
Sb
