Bit of a weird problem
The button on my reverb was a bit stiff – needing a lot of pressure to get it to work.
So I thought I’d bleed it.
Followed a video online (the BikeRadar one) which I’ve used before to bleed the same post with no problems.
Rotate the bike in the stand so the actuator end is higher than the saddle.
Rotate the actuator so the bleed port is highest.
Fill one syringe 3/4s of the way with the Rockshox fluid. Push it through a little to get rid of bubbles.
Undo actuator grub screw and screw in syringe.
Do the same at the saddle end, with an empty syringe that is fully depressed.
Raise both syringes upwards
Now here’s the problem
I can’t push the syringe with the fluid down – it’s solid. If I press hard some fluid starts to escape around the edge of the syringe nozzle. Pulling up on the empty/saddle syringe doesn’t help.
The syringe works fine when it’s not screwed in to the reverb – can push fluid out.
What could be the cause of this? Have tried it a few times, even undone everything and refollowed the video but still the same.
