'dales around then used T6061 (mebbe they still do) – it was heat treated after welding, so you can't easily fit disk brakes unless it's the kinda thing thing that has a bar up to the canti boss for support. (Tho' there is the A2Z thing
http://www.retrobike.co.uk/forum/viewtopic.php?p=521329&sid=0606d2e59880f4fcde0556274c226524
– dunno if that's better or worse for the frame.
But I'd just fit V-brakes.
IIRC the canti dropouts were around '89-90, but the replaceable ones probably 90 onwards.
I'm not sure anything around '90 even allowed for suspension forks eg here's a '91 BOTE:
http://www.retrobike.co.uk/forum/viewtopic.php?t=36185
And I'm pretty sure > 1" steerers were later than that.
>80mm – 100mm travel.
No more than 80mm, and even that's pushing it a bit I suspect. Most 80mm forks now are about 440mm drop>crown, I think the original forks are probably more like 395.
Some of the few forks you could buy then were Rockshox Mag21s (iirc) or Manitous – dunno what the measurements of those were, but the available travel was something like 60mm or less (50mm on the Manitous?). An old set of elastomer Paces would almost fit the bill, except for the availability of the elastomers nowadays (ie you can't get 'em)
The 24" rear wheel was (I think) before '88 – a mate had an '88 that was 26", after having a go on that I splashed out on an M600 ('89)…600+ quid at the time 😮
Had a wacky white/red/purple paintjob..sadly that croaked (longitudinal crack along the top-tube where it wrapped the seat-tube) about '91.
I wound up with a level top-tube M500 as a replacement (probably should have given them the extra 50 quid or so for the BOTE version – they'd changed the ranges/pricing around…) which I used regularly 'till '97 and is sitting in the garage waiting for it's rebuild (as is my '96 M2 stumpie…)
Worth trying to patch-in any missing paint? – Imron was a bugger for chipping on the chainstay but seemed to stick ok elsewhere…
