Viewing 3 posts - 1 through 3 (of 3 total)
  • Can you use the reverb bleed kit to bleed avid brakes?
  • kurt
    I have a spare reverb bleed kit and was wondering if anyone has successfully used this to bleed their avid brakes?
    Kurt
    vincienup
    In principle, yes.
    Major health warning though: your reverb uses suspension oil and your Avids use DOT brake fluid. Both are oils but must not be mixed. Personally I would never use a syringe kit I’d used on a Reverb to bleed my brakes because of this, but some will happily tell you it will be fine if you wash it out well first. Obviously if it’s a spare new kit this doesn’t matter right now… 🙂
    kurt
    Thanks for that, yeah, got one for each so no danger of contamination.
    Kurt
The topic ‘Can you use the reverb bleed kit to bleed avid brakes?’ is closed to new replies.
