Viewing 40 posts - 1 through 40 (of 65 total)
  • Can you make carbon fibre stuff in your garage?
  • molgrips
    I have an idea for a bike component. Non structural non critical mass f course, just needs a bit of stiffness rather than being flappy breaky plastic. Like the elbow rests on my clip on tri bars.
    wwaswas
    cynic-al to the thread! cynic-al to the thread!
    Tom-B
    I believe that a spoon is the stwers preferred material….
    crikey
    Yes.
    I busted up a derailleur hanger and had one made. The guy who made it refused any payment, but suggested I buy him a book. When I took the book round, he showed me his latest creation, which was a carbon fibre telescope and tripod.
    Eminently doable, especially for you because you’ve got the interest and the think-about-stuff-a-lot characteristic!
    aracer
    Of course you can – people have built carbon frames in their garage.
    Though I’d take issue with tri-bar arm rests being non-structural – you fancy one breaking when going over a bump at speed?
    wobbliscott
    Yes. It’s just like glass fibre, but instead of glass fibres, carbon fibres are used. The principle is identical. A guy at work races F1 hovercraft and makes his own CF tubs/chassis in his garage.
    footflaps
    See if you can find a copy of One Man’s Dream – The Britten Bike Story (video), 1995, Ruffell Films. He build the bike in his shed inc DIY carbon fibre parts. Went on to win loads of races.
    allmountainventure
    This guy does, down the road from me in benaocaz http://www.carbonbikes.es/index.php?route=product/category&path=59
    Pretty nice stuff too.
    molgrips
    I didn’t mean the arm rests were non structural, I meant that what I have in mind is non structural but could do with being as stiff and thin as the arm rests, which are carbon.
    I saw a bloke on the telly laying cloth then spreading on a resin, and pressing it in a form. Might need baking though.. Hmm…
    richmars
    Yes, I’ve made three frames (road, hardtail and full suspension) and assorted bits in my garage.
    molgrips
    What kit did you need?
    stumpy01
    Yeah, Richmars up there ^^ is a top garage tinkerer and does carbon fibre stuff….it can be done!
    richmars
    Google.
    It’s a lot easier now. You can buy stuff on line, and lots of info.
    I started by buying carbon tubes and lugs and sticking it all together (not as easy as it sounds), then made my own tubes (carbon cloth wrapped around a foam core, and stuck it all together. Ideally you need someway of making (or buying) the metal bits, like drop outs and bottom brackets (I had access to a lathe and mill).
    A vacuum pump helps, but you don’t need an oven.
    It’s fairly easy to make parts, less easy to make them look ‘nice’ unless you make moulds (which you can with MDF).
    Sancho
    my friend doesnt buy bikes anymore he just makes what he wants in carbon from hardtails to dowhill frames
    bikebouy
    You need a vacuum, borrow that thing sitting unused in the corner under the stairs 😉
    molgrips
    I only need one formed sheet. I could do it on a vacuum former but it would be a bit crappy. Tempted to make a prototype to send to someone to have made. But that would cost money 🙂
    richmars
    Pictures of a rear mud guard I made a few years ago:
    clicky
    molgrips
    Nice work. You made the form by hand or is it cast from something else?
    richmars
    I used a plastic mud guard as a pattern, made a carbon mould, then used that to make the part. Pretty sure I used vacuum, but don’t have any photos.
    garage-dweller
    A number of successful international (or more correctly 10 sqm) canoes have been built in garages I believe. If you can home make a sailing boat hull then non structural stuff should easily be a goer for bike bits.
    compositepro
    people build planes in sheds….not models
    sharkbait
    Off on a course next month to learn about making CF parts using resin infusion – most cool. Thinking of setting up a small sideline making parts. Bikebouy, the hoover is not going to do the job I’m afraid 🙁
    aracer
    You need a vacuum
    No you don’t – certainly not for non-structural stuff. I’ve done a fair amount of composite stuff (mostly with kevlar as I got a job lot from an ex-gfs dad who worked in testing bullet proof vests and stuff like that). Have never used a vacuum – simply loaded up with weight normally, though sometimes not even that. You’ll just end up with a bit more resin and so a bit lower strength/weight. Though you can also do tricks like wrapping in tape with pinholes to squeeze resin out.
    Don’t think I’ve got any pics, but I guess the best thing I’ve made is a sandwich construction kevlar map-board with foam in the middle. As mentioned above I just loaded that up with weight (wrapped the board in carrier bags), and it is structurally strong enough to use as an improvised tri-bar.
    cookeaa
    I have a couple of sq m of 300g carbon fabric, some fibreglass mat and an out of date west epoxy pack sat in my garage waiting for me to pull my finger out and try one of the numerous projects on my to do list…
    It can all be done just takes time, research and some planning.
    cynic-al
    Aracer – taken it over any bumps? 😛
    As above it’s not difficult, forming in balsa is easy and light.
    For a mudguard etc I’d use a sandpit, plastic bag, a male form and lots of weight.
    geetee1972
    Have a look at Swarf Cycles. Adrian built the bikes you will see there pretty much in his shed including a full carbon swing arm.
    irelanst
    I did a fair bit a long time ago, mainly in glass but some carbon for model gliders. Most of the stuff was cloth over foam core with UD stiffeners which was then bagged and I used an old compressor from a fridge for the vacuum and a hotbox made from plywood and a fan heater to speed up the cure. I could get fairly accurate and repeatable results on the profile.
    I did make some parts using female molds and bladders but unless you plan on making a lot then it’s a fair bit of effort and soul destroying if you don’t get the release prep right.
    There is loads of information on model aircraft sites. Oh and microbaloons are one of the coolest things you will ever use.
    Macavity
    Macavity
    “Can you make carbon fibre stuff in your garage?”
    No.
    Its so full of junk I can’t even get in through the garage door.
    bikebouy
    I’ve built foils for dinghies (foiling moths and fins for windsurf boards), I needed a vacuum, rather a really good vacuum pump which I borrowed from a boat builder…
    Carbon Weave,
    Medium
    Mould
    Pre Formed Shape
    Strong (1mm thick) vacuum bags
    Vacuum pump
    Suck, suck, suck, in room temp harden overnight.
    sharkbait
    You need a vacuum
    No you don’t
    Unless your happy producing pieces that are [comparatively] heavier and not as strong as they could be.
    molgrips
    I was thinking of making a mockup out of something bendy, and casting a male and female mould. Then I could squash the carbon between them both.
    Macavity
    meehaja
    Ok, so i know there were early issues with glue failures etc, but if its good enough for indy fab’s… how hard would it be to build a steel lugged, carbon fibre frame? Presumably its more complex than pushing the tubes in, adding a load of resin and keeping it somewhere hot?
    bikebouy
    Without getting too complex 😆 from what I learned, it’s all about what bonding agent you use and the weave.
    When doing the foils (pattern off an original (male/female sandwiched together) i had to soak four sheets of weave then lay it ontop of the releasing agent (white silicone stuff) then pour the bonding agent and nead through the weave, this was the hard bit as it’s bloody messy and you need gloves 😳 I used a squdge made out of wooden mallet. After pressing 4 male and 4 female weaves I sandwiched them together and clamped them hard, open both ends and two breathers in the mould, covered the whole “mould” with 1mm thick sealed plastci bag and then formed a nozzel for the vacuum which I placed midway along the mould. Enter a lot of suck at room temp and left to cure overnight. Came back the next morning to find some creep out of the mould (expected) and then opened out the mould and trimmed the foils down. Quite remarkably (for me) they came out straight and true with little trimming to be done. I then built up the top edge of the foil with move weave to fashion a union/junction for the tiller ext and did a similar thing to above except it was more freeformed and harder to vacuum well enough.
    The fins were peasy compared to the foils so not really worth bothering to talk about.
    I have bonded masts together and spar/shroud attachments/junctions without vacumming but to get the best bond vacuuming sucks out all the trapped air and oxygen nonsence that contributes to mass failure 😆
    irelanst
    Your part might be suitable for that method but generally speaking I wouldn’t do that. I did try that method once and the results weren’t very good, I ended up with voids and lots of slippage between the layers of cloth (although that would depend on geometry). IMO, female mold with bladder, or male mold with vacuum bag is a much better method.
    aracer
    I said that. For most home builders, and particularly for non-structural stuff like molgrips wants it’s not that big an issue. Most of the air can be got out by good use of a roller/brush and use of weight/compression.
    molgrips
    Hmm.. the vacuum method requires me to source a pump of some kind.. which is a whole pre-project.
    spazzolino
    Hey molegrips,
    The process and the equipment you need will depend on a number of things:
    Size of part, surface finish requirements, performance requirements, your budget, how much time you have and also how many general tools you have in your possession.
    I can let give you step by step run down of what you need for the project and how to do it of you are serious.
    You can pm me if you are interested.
    clubber
    I know people who just use cheap vacuum cleaners off gumtree – they don’t really like being left sucking on nothing for long periods and tend to die eventually. ( 😉 )
The topic ‘Can you make carbon fibre stuff in your garage?’ is closed to new replies.
