yes you can*, and no it isn’t, well not quite… **
* Some merlin frames (US Titanium Merlin) frames were built wiht headtubes that took them, and I believe there is at least one Seven frame out there too.
** the headtube itself is the same size as 1.5 inch headtubes, and 1.5 inch headsets will fit, but headshoks use a proprietary headset which is 1.56inch on the internal diameter of the bearings and it’s an interference fit on the steerer, so not like normal headsets.
You could also get a frame built with a headtube that would take one, I’m also pretty sure any 1.5 inch headtube of the correct length (this is critical due to the interference fit mentioned above, the bearing sits at specific spots on the steerer) could have the headshok/cannondale headset cups fitted as it’s the bearings that are different, not the internal diameter of the headtube itself, although from memory they might use a different cup insertion depth…
