Can you cut ODI Ruf...
[Closed] Can you cut ODI Ruffians?
[#1645877]
As title really, just got some gripshift and currently use ruffians. Can I cut them shorter or do I need new grips?
Posted : 26/05/2010 6:08 pm
Pretty sure they do a special short version for just such an eventuality.
Posted : 26/05/2010 6:10 pm
 Tim
if they aren't lock ons...why not?
If the diameter doesnt match though it can get umcomfortable as your hand rubs on the ridge
i used to use Sachs Wavey shifters with cut down Onza Ules back in the day 🙂
Posted : 26/05/2010 6:12 pm
yeh, they do a shorter one but you can cut them - I have
quite hard to get a really good straight finish to the rubber though; you might want to use the little thin spacers that sometimes come with gripshifters
(mine are lock-ons BTW - now just on the outer collar)
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=10473 ]Rogue not Ruffian though![/url]
I tried the shorter lockons when I had a Rohloff.
I could feel the lockon ring between the grip and the shifter so i just used a cut down normal length lockon with the remaining clamp on the outside.
Worked fine.
Posted : 26/05/2010 6:24 pm
