Can MKS tugs be wid...
[Closed] Can MKS tugs be widened?
[#255815]
My dropout is 6mm steel. Is there enough meat on a 5mm MKS to be ground out to fit?
Posted : 29/01/2009 2:30 pm
nope - you should use the MKS fat tugs instead which are 8mm wide
out of stock at hubjub though
Posted : 29/01/2009 2:37 pm
But I want a sleek Allen type...
Posted : 29/01/2009 2:55 pm
Surly ones look nice and dont have enclosed clasps so will work on fat frames.
SO do On-One ones but they have 2x allen bolts with small locking nuts. They dont look very purty though.
Posted : 29/01/2009 2:57 pm
You could grind the ends down on the skinny ones, but it'd be tricky unless you just take the whole shoulder off so they don't come round the sides.
Posted : 29/01/2009 3:32 pm
they are very hard metal. have a set of fat ones that were not quite fat enough to fit my old klein dropouts, and despite a lot of effort i could only remove about 0.0001mm of material.
You are welcome to my MKS chaintugs for £10 posted if you want?
Posted : 29/01/2009 4:34 pm
