Viewing 8 posts - 1 through 8 (of 8 total)
  • can I use engine oil 0W-30 instead of 0W-20
  • wolfenstein
    Cannot find any 0W-20 (my manual recommends) in Eurocarparts which is just down the road from me.. but they have 0W-30. thanks
    Cougar
    Match up the specification, not the numbers.
    Also, http://singletrackworld.com/forum/topic/engine-oil-talk-to-me
    craigxxl
    What car are you running that takes such a light oil? Are you sure you are reading the oil spec for the UK
    wolfenstein
    2014 toyota yaris 1.3 petrol..manual preferred 0W-20 I assume full synthetic
    bear-uk
    If you go into Europarts they will match the oil to your car from the Reg. I would have thought it should be around 5W-30 fully synthetic. Its a common oil thats in my 307 Pug and Vivaro van.
    thomthumb
    try a toyota dealer.
    If it was a 15 yr old car then it would be worth the risk – not on a 1 yr old – presumably still in warranty. it would probably void the warranty on the engine: big risk IMO.
    jota180
    Check the spec in the handbook, it’ll be something like ILSAC GF-5
    andydicko
    We’ve got some 0W-20 at work, could sell you some if you’re Halifax area
The topic ‘can I use engine oil 0W-30 instead of 0W-20’ is closed to new replies.
