Viewing 7 posts - 1 through 7 (of 7 total)
  • Can anyone recommend a bike frame builder in Oxfordshire or Berkshire area?
  • singletracksurfer
    I want to spread my rear end (on a steel CX bike from 130 to 135mm).
    Thanks
    bencooper
    Any good bike shop should be able to do it – or you can do it yourself. Just get a block of wood and hammer it down between the stays – you’ll need to go further than 135mm as it’ll spring back.
    singletracksurfer
    really – have you or anyone tried this (and it worked ok)?
    simon1975
    I’ve simply spread the dropouts by hand and put the wheel in. It’ll soon “cold set” at the new spacing (if it’s only 5mm different!).
    singletracksurfer
    Cool ok thanks, I’ll give that a go then.
    bencooper
    Did it with a block of wood a few times before I got the proper tool.
    singletracksurfer
    block of wood bodge it is then. Ta
The topic ‘Can anyone recommend a bike frame builder in Oxfordshire or Berkshire area?’ is closed to new replies.
