steve – you’re bolting your rear triangle to the front yes?
Yes, that’s the plan. Could make the location for the swingarm slotted to allow some movement.
Does it really *need* a disc brake? One more sharp spinny thing for her to chop her fingers off with? Also can you get disc brake levers small enough?
Good point but I think with a 140mm rotor it should be OK. Most levers have reach adjustment now so hoping something would work. Could always make a shorter lever.
Saying that – putting the adjustment at the front is a good idea and keeps the wheel spindle / stub axle mount simple and solid.
Yeah, I think that’s the way to go. Would like to keep the rear as simple and strong as possible.
BB mounted tensioner would be the simplest method but will look at a couple of other options. It would be really easy to make a slotted mount for an adjustable roller, fitted to the chainstay..
