Cable replacement?
[Closed] Cable replacement?
 Moe
[#1469449]
Need to replace the rear* gear cable, all fine except I can't see how you thread it into the shifter. I've removed the cover but can't see (or want to risk) taking anything else apart ......... guidance please?
*can't spell it!!! ....... you know, the 'd' word ..... I know, I could just look it up in the time it's taken to type this but hell!!
Posted : 01/04/2010 3:22 pm
what type of shifter?
have you tried to push the old one out of the shifter yet?
Posted : 01/04/2010 3:24 pm
Shimano levers have a little grub screw on them behind the shift levers where the cable pops out of.
Posted : 01/04/2010 3:42 pm
 Moe
Sorry, yes, trigger shifter.
had a quick push and it didn't seem to want to come out, I'll give it another try. Is it that simple?
make sure that the shifter is in the correct gear - for a rear shifter it will need to be in '9' and and front in '1'. there should be a tiny hole to thread the cable through. big lamp/torch will help you.
Posted : 01/04/2010 3:44 pm
Moe,
is it shimano? sram? other?
on shimano tech dos website loads of info:
example for SLX trigger cable replace:
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/SI/SLX/SI_6PZFA_002/SI-6PZFA-002-En_v1_m56577569830647029.pdf ]SLX Instructions - Clicky[/url]
same sort of info on SRAM site as well (under dealer support)
Posted : 01/04/2010 3:53 pm
 hug
if they're shimano you can download/print a set of destructions, but i seem to recall that you keep pulling the trigger 'till it's shifted all the way up (or down if yours is that way inclined) then you should be able to push the cable inner through, if it still resists try just a little fressure on the thumb lever as you push the cable.
if on t'other hand you have those dual shifter-brake & gear things then I have no idea
 Moe
Thank you all very much 😀 it's funny how the smallest things can be the biggest headache!
Posted : 01/04/2010 4:00 pm
