So, if I understand it right, then from a reset it should work as an access point creating its own network, then after config it drops this network and hopefully connects to the network you’ve told it to. From what PP is saying, after a reset it still isn’t presenting its A5 network. My guess is it’s either iffy design of the networking side, or channel interference with the existing networks. Either way, the manual gives little technical setup for the networking side. Overall impressions is that it’s a very expensive speaker which looks nice and probably has good sound, but the networking side may be a bit cheap and certainly poorly documented. I get the impression PP doesn’t enjoy this type,of problem, and why should he, so probably best to return and get something different.
