Building a 150mm Ho...
[Closed] Building a 150mm Hope rear wheel
[#1936133]
Advice please. My new frame needs a 150mm x 12mm rear wheel. I was thinking about buying the parts and getting someone to build the wheel.
Might sound like a dumb question but is this the right hub:
http://www.chainreactioncycles.com/Models.aspx?ModelID=7568
Do I then use these QR's:
http://www.chainreactioncycles.com/Models.aspx?ModelID=31895
or do I need a special one?
Thanks
Posted : 27/08/2010 8:56 am
Presumably your frame came with the through axle? It'll be much fatter than a QR. Like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=26370
Posted : 27/08/2010 9:25 am
Yes thats the right hub & no, thats the wrong QR.
You need a 12x150 axle. Normally bolted, unless you buy a rear Maxle - which would be a waste of money as they are crap on DH bikes.
Posted : 27/08/2010 10:25 am
Good spot. I think it did.
Thanks
Thinking 36h for strength. No reason not to is there?
Posted : 27/08/2010 10:26 am
A good wheelbuild with 32 will be stronger than a poor with 36.
Having said that, a good wheelbuild with 36 will top them both.
Posted : 27/08/2010 10:31 am
Wouldn't bother with a 36H, 32 will be fine. Cheaper & lighter too!
Posted : 27/08/2010 10:32 am
32 might also be easier to get spare rims for in the future.
Posted : 27/08/2010 10:37 am
Easier to get the rim you want in 32h, (?better resale value as well?) and if you buy the spokes from crc too they supply 36 so you get a few spares.
Posted : 27/08/2010 11:23 am
I'd say you might as well go for a 36h. It _will_ be stronger if it's properly built. The weight difference (of four spokes!) will be negligible, and it's not like they're some peculiar boutique size - most decent rims and hubs are available in 36h.
DO get double butted spokes. Don't skimp here - good quality spokes (I prefer Sapims but lots of people on here are DT fans) make a huge difference to wheels and plain gauge spokes will NOT build a stronger wheel. Look at Sapim Force if you're going to abuse the wheel, they're 2.3mm at the elbow, 1.8 through the length and 2.0 at the thread. Excellent spokes.
: P
P.S. drop me an email (pete at ratracecycles dot com) if you want advice or a quote.
Posted : 27/08/2010 11:30 am
