So, i have a single skin concrete block garage built on a slab. its been painted inside & out. On one side my neighbour has a concrete slab that is slightly higher than mine. During heavy rain fall the water seeps in via the bottom layer of mortar that my blocks are on, makes that side of my garage damp / wet internally.
My plan is to add a strip of mortar/conrete the length of the side of my garage (7meters), maybe 6″ wide & 4″ high to take the water away from the base of my garage and to direct it to a free draining area.
A run of 7 meters that small is liable to crack / break, should i add a length of rebar? do it in 7 x 1mtr sections? add masonary nails into block mortar for my addition to grip to?
What kind of mix for this? i’m not adverse to a little over building!
Any tips appreciated. Ta
