Budget torque wrenc...
[Closed] Budget torque wrench?
[#6933530]
I am in the market for one of these. Could anyone recommend a wrench that is easy to use and well priced? Thanks in advance
Posted : 15/03/2015 2:14 pm
I got one from on one. Its alright.
Its not really difficult to use a torque wrench you just line the red line/window/dial with the required torque setting. Tighten the bolt up until it clicks.
Posted : 15/03/2015 2:19 pm
I just bought one of those preset Ritchey torgue keys, the 5Nm one as thats what's on all my stem and seat clamp bolts
Posted : 15/03/2015 2:27 pm
this
[url= http://www.topeak.com/products/Homeshop-Tools/combotorq_bit_set ]http://www.topeak.com/products/Homeshop-Tools/combotorq_bit_set[/url]
Posted : 15/03/2015 2:40 pm
I got one of these for occasional use:
http://www.amazon.co.uk/Part-Cycle-Bike-Torque-Wrench/dp/B004XHXE1I/ref=sr_1_1?ie=UTF8&qid=1426439378&sr=8-1&keywords=m+part+torque+wrench
It works just fine, but a few of the bits have started to rust very very quickly. But I have loads of different tools, so it's no biggy. Storing it indoors now (not in the shed).
Posted : 15/03/2015 6:12 pm
I've got a Sealey STW1012 that works well
It needed adjusting when I had its calibration checked to get it within tolerance, the calibration and adjustment was £24, but it's now within +0.31% at its worst
With the adjustment costs it's still a budget item when compared to some
Posted : 16/03/2015 7:56 am
Superstar components were doing a Christmas discount and their's was £25 delivered for a really well made wrench and bits.
Not sure I'd pay full price for any torque wrench unless you need to fit carbon stuff. Or have the mechanical abilities of a gibbon. Actually maybe I should have got one sooner. ..
Posted : 16/03/2015 8:01 am
I also have one of those Sealey ones from Amazon in 2nm - 24nm flavour. Its quite big and heavy but works ok. I've not had it calibrated yet but I presume it might actually be cheaper just to buy a new one once it starts losing its calibration.
Posted : 16/03/2015 8:49 am
Borrow a friend's to learn how to feel it. 1Nm = 1kg per 10cm.
Posted : 16/03/2015 10:36 am
M-Part do a nice one for £50 including a selection of bits.
Would be able to order from LBS
Posted : 16/03/2015 11:16 am
That Topeak one mentioned by [b]jsyng[/b] has been working good for me for the last 10 months. "Cheap and cheerful" option, but pretty damn good for the money! I paid £13 in Halfords.
Posted : 16/03/2015 11:33 am
Topeak one seems decent for the cash
Posted : 16/03/2015 11:42 am
I was looking at one of these:
http://www.wiggle.co.uk/lifeline-essential-torque-wrench-set/
Other options here good info too.
Posted : 16/03/2015 1:02 pm
the wiggle item will take away the hap hazard guesswork of the the topeak item. I've got one of the sealey items (made by laser tools item number 3451) and works just dandy - provided you have the 3/8 sockets to match
Posted : 16/03/2015 1:58 pm
 dpfr
I got the Lifeline one but didn't get on at all well with it (I am damned if I can tell when it's reached the right torque), so replaced it with a Park Tools one which was more than twice the price, but doesn't rip the heads off bolts. I've kept the Lifeline one because it has a neat set of different heads but that was an expensive way to get hold of those. Or maybe I am just a gibbon?
This is a chinese made torque wrench that is sold under dozens of different "brand names" including PRO, Pedro's, etc.
shop around, you can pick them up cheap. they work just fine...
Posted : 16/03/2015 2:01 pm
I got a Clarks one from Machine Mart still works fine with no corrosion although I've not had it recalibrated.
Posted : 16/03/2015 2:06 pm
I've got that topeak one - nothing has broken or come loose so seems to do the job perfectly well
Posted : 16/03/2015 3:44 pm
Hmm I have an old Norbar (5-40lbf) one that I bought for my motorbikes, just been told it £40 +vat for a recalibration, anyone think it worthwhile getting it recalibrated or just buy one of the option above?
Posted : 18/03/2015 4:01 pm
just out of interest - how often do people get them calibrated? Is is something that needs done after a fixed time period or after a certain amount of use?
Posted : 18/03/2015 4:05 pm
That lifeline one looks identical to the one I bought from On-One (or was it superstar?!) either way mine has a nice obvious click. 😀
Posted : 18/03/2015 4:07 pm
When tightening stem bolts 5nm really doesn't feel tight enough.
The bolts will do half a turn more til I feel it's tight enough.
Am I just being paranoid?
Posted : 18/03/2015 4:21 pm
No Zippy - you're over tightening your bolts. What's the point of having a torque wrench if you ignore the correct settings 😥 ?
Posted : 18/03/2015 4:37 pm
"How often do people get them calibrated?"
My calibration certificate was valid for 6 months. I won't be having it done that regularly though
Posted : 19/03/2015 7:44 am
 LeeW
Calibration depends how much you use it. Do you want it for the bike or bigger stuff? In other words what range do you want?
My labs calibrate thousands of these per year for Aerospace and Automotive companies, there's plenty of poo out there but if you're only going to use it a few times per year it's less of an issue.
Or you could measure the length of your current wrench and calculate the weight you need to hang off the end
Posted : 19/03/2015 8:08 am
Mine is about 20 years old so think it's due a check (unused and unwound), as I've a carbon FS frame coming, I'm gunna get it done.. Looking at the price of a new (norbar) replacement is double the cost of a recalibration (4x that of the cheap units listed above) maybe costly but seemingly worthwhile having a decent tool checked. Not exactly a budget option but..
Posted : 19/03/2015 10:17 am
 LeeW
I think I live near you Z1ppy, I'll do it for cake :))
Posted : 19/03/2015 1:53 pm
 LeeW
Bump, as I really want the cake.
Posted : 19/03/2015 8:16 pm
