unless you,re doing the more downhill type of riding, i cant really see the advantage of any shimano brakes above m615,s, they are the most value for money brake on the market and are usually reliable, iv,e used avid, shimano xt,s, slx,s, and now will stick with 615,s, levers and calipers are cheap to replace, they are just as good as xt,s, what more do you need, unless you want the bling factor, ive also tried a friends new xt m8000,s , they look nice but not much difference in power compared to my brakes, and he has already had the dredded bite point problem, which ive found my talking to various people seems to be down to dodgy caliper seals, i recently had this problem with one of my sets of m615,s, which shimano warrantied, it was indeed down to the caliper, so my advice to peolpe having varying bite point problems,try a new caliper, if thats not the cause, at least you have a spare, usually when bikes are left unused for a while, the seals seem to dry out, my solution is, if your not going to be using the bike for a while, clean the caliper seals with shimano mineral oil before you put the bike away, that will help keep the seals from drying out, cheers steve.
