I’m having problems with the front brake on a 2 month old bike – I’m planning to ask the shop to sort it but I’d like opinions on the issue first. Brakes are SRAM Rival hydraulic.
After a few rides it was obviously losing power and eventually had no resistance in the lever at all. I took it in to the shop, they bled it and it seemed to work fine after. It was squealing when they gave it back so they cleaned the rotor thoroughly.
I then changed the pads as it was still squealing a bit and didn’t seem as strong as I’d expect. After bedding in the new pads it was great.
Since then I’ve ridden it 3 or 4 times. On Saturday I started thinking it was losing power again but wasn’t sure. Between that ride and today it’s been stored in the house and there’s no way anything got on the pads/rotor. I take it out today and it immediately starts making an incredibly loud screech under any braking (it’s dry out). The brake is still working and the lever feels fine, but the braking power is definitely getting weaker again.
Given the symptoms I’m thinking a slow leak of fluid from the caliper? Should I be asking for a replacement caliper or is it repairable?
