^^^ very good 😉
The trick is just to make sure you learn how to properly strap your bike on, don’t be afraid to ask the driver to show you how on the first run (they’ll take the piss, but that’s better than getting to the top to find your bike missing…. )
They tend to want to strap over the grips to help stop the straps slipping (as grips are, er, grippy!) which can chop the grips up a bit if you run really soft grips or it’s wet (and hence everything is covered in slat grit).
Unfortunately the uplift track is not tarmac’d and so the bikes do get a bit of a shaking so try to get your bike on towards the front of the trailer, not directly above the trailer wheels for the smoothest ride (also, don’t sit over the van rear axle if you don’t like getting a wobbly ride too…..)
