@renton
I had 5 stumpjumper frames 2 with bb30, 3 with PF30. Each had press fit BB issues, 1 of the bb30 frame was replaced under warranty due to machining errors in the BB shell
Each PF30 frame had slight variations in the BB bore tolerance. Last frame the bore a little too large, meant using a praxxis BB with fibre grip on the nylon sleeve and BB seats.
Tried greases, anti seize, wheels BB, SRAM BB, different cranks native 30mm and ht2 xt.
Totally depends on the frame itself, and it’s tolerances.
But you can generally get xt or slx running on praxxis conversion BB with some reliability, the bearing benefit from packing with marine grease before use and cheap to replace as needed
The praxxis comes native for bb30 with nylon sleeve for pf30
