sorry…
so my wife has just bought new bike boost front and rear, whereas mine is 100×15 and 142×12.
all fine so far. there is a spare set of non boost wheels lurking about. in a pinch, could i make the non boost wheel set fit the boost bike – without relacing the wheel, so emergency only, so we can share a spare set of wheels
this is what im thinking
FRONT seems simple – 2off 15mm id spacers 5mm wide- and a 5mm spacer for the disk and longer bolts done.
REAR – 2off 3mm wide spacers 12mm id and a 3mm spacer for the disk. leave the cassette alone and just tweak the limit screws – as a bodge – the rim will be in the middle and if its lift assisted she wont need the granny anyway.
question – am i correct in assuming the rim is in the same place re the ends of the spacers, rear boost v. non boost?
http://fcdn.mtbr.com/attachments/wheels-tires/1041357d1452362665-hope-hubs-pro-2-evo-pro-4-boost-not-boost-wpid-pro-2-evo-front-rear-boost-comparisons.jpg
this says they are
