Any you wood burners also have a boiler on the back? I’ve had a wood burner for a few years but just moved to a new house. I plan to replace the gas fire in the living room with a burner but wondered if I should consider hooking up to my tank while I’m at it (the boiler and hot tank need to be replaced anyway). I’d be keeping a gas boiler using wood as an additional heat source in the winter months.
Do you lose any noticeable heat to the room at all or does it capture heat that would otherwise have been wasted?
Is there noise from the water pipes? Last thing I want is a constant water gurgle in the living room but guessing that would only happen if air is in the system?
Is a heat accumulator just a bigger water tank or does it work differently?
Do I have to have a heat loss radiator for thermosyphoning? Also, can there be any downward bend in the pipes between the stove and this point? This could be my problem. I could join from stove to tank upstairs fairly easily but no radiator is conveniently situated between the two and the pipework would go up to the floor above but then also turn down a couple of feet before entering the room with tank.
i’ve read about the Laddomat which seems a good idea but anything else i need to consider?
If you put the stove on for a while and have lots of hot water is there a way the boiler can realise it doesn’t need to come on?
