I have found that they can, albeit rarely, work loose and it is possible to re-torque from the other side to correct this. However I once left mine for over 2 years without checking, they were working OK with no play, only to find when one of the lower bearings did finally go, part of it was welded to the frame axle and required a lot of blood sweat and tears to extricate and replace.
I now replace all 4 bearings as a matter of course every year and if any are actually shot I send them back to Jungle who have replaced them under the warranty. I did invest in the correct SC tools as well. Another tip if you don’t want to pay the LBS for labour or buy the tools is to buy the carbon link complete with bearings fitted – no extractor required and very easy to fit.
