Our old house has had the stone chimneys and fire places plasterboarded over.
The front room has a wood fire surround with a horrible marble effect backing board with a hole in it and a disconnected gas fire sat on the old stone hearth.
The back room has been completely boarded over, and I think I’m going to leave it like that (we don’t use the room other than to store my bikes and the un-used dining table/chairs!)
I want to remove the fire surround and backing board and expose the stone lintel and stones up each side of the fire place. After, I’d like to blend the plaster to meet up with the joints in-between the stones, to make it a feature.
Question is, anyone know the best way of doing this? The plaster board will be between 20 to 50mm above the stones, so the return that I want to sculpt back to the stone will need some support. Fill the gap with builders foam or screw timber to the back of the plasterboard (would need shaping to suit the stone underneath it)?
Also, what plaster to use? In STW fashion, I’d like to install a wood burner eventually, so I’m a bit worried about the moulded plaster just shrinking away from the stone when it gets hot…
Any tips welcome!
(by the way, when the wood burner goes in, I’ll get it and the flue installed by pros)
