evening all 🙂
looking for a bit of guidance re: blackspire stingers.
I run an e-type, iscg stinger on my bike….teamed up with a double chain ring and bash.
the device it’s self works, and since I’ve fitted it I’ve had no chain drops etc.
my question however is: should the roller on the stinger rotate???
I imagine it should….I’ve lost at least two rollers because if I tighten ’em up to the correct tolerances (ie 12nm, this figure came from blackspire themselves) then the roller won’t budge. This means I slacken em off to such an extent that they work loose when I start hitting the rough stuff.
as a compromise I tighten the roller just enough so I can force it to rotate by hand. I’ve lost no more rollers since doing that but I still cannot the damn thing to rotate with just the chain rolling over it.
anyone shed any light on how you’ve got your own stinger setup? and more importantly can you get the roller to rotate?
cheers in advance lads (and lasses) 🙂
NB just to clarify the stinger roller is just a hair width away from touching my bash guard.
