Blackberry Help - ...
[Closed] Blackberry Help - Transfer contacts to Nokia phone?
[#3869871]
My Blackberry screen has died!
How can I transfer the contacts to a standard Nokia phone?
The rest of it still works and it receives calls, no doubt it could dial out if I could see the screen.
I have connected it to my PC and backed it up. I can open the folders in windows and see pics and stuff.
When I first got it I had my contacts saved on a Sim Card on a normal Samnsung phone and simply put the card in the Blackberry and could access the contacts.
However, I have to use a basic Nokia phone until I can get the blackberry replaced but when I put the sim in the phone I cannot see any contacts.
Am I missing something obvious but it would appear that I am now almost forced to use a Blackberry to save my contacts with the transfer to new device function in the software?
Any ideas?
Posted : 14/04/2012 12:26 pm
Can you back up your contacts to the PC, then sync the Nokia with your PC ?
Posted : 14/04/2012 1:25 pm
Saving contacts to a SIM these days is a bad idea for a number of reasons, but generally you cannot fit a modern multi-line address book onto one.
Syncing via the PC would be the way to go. I'd probably use Outlook as the glue here; sync the BB with Outlook, then sync that back to the Nokia.
Alternatively it might be possible to export to / import from a file, but I've neither Blackberry Desktop nor PC Suite here so I'd be guessing at best.
Posted : 14/04/2012 2:40 pm
