Bit of VS .NET 2003...
[Closed] Bit of VS .NET 2003 help please
 Earl
[#1417132]
VS .Net 2003 to debug some C code.
In the watch window the values of my chars are being displayed as numbers only (ASCI in base10 I assume).
Is that a settting that will show me both the numerical ASCI value and the 'Alphabetical' character? ie 82 = 'R'
Hopefully I'm asking the question right as I kinda out of my depth here.
Posted : 16/03/2010 4:20 pm
From memory you can right click and choose other display formats.
It should really show the ASCII characters for the char type , unless they are being stored as int or something, in which case you can type in a suitable cast into the Watch window.
Posted : 16/03/2010 4:42 pm
 nbt
you can add multiple watches, but you will need to run a conversion on the string value which VS.net doesn't really like doing. best way might be to add a line which converts the char to a string and add a watch on that variable - either stick it in an IF #DEBUG so it doesn;t compile in release mode, or better still remove it when you;re sure your code works as required
Posted : 16/03/2010 4:44 pm
 Earl
Right mouse click only gives me option for Hex display.
Posted : 16/03/2010 4:45 pm
Normally it is pretty good at working our types. Are you being slack with typing?
try adding a watch with a cast, eg: (char) my_var
or use the memory window: type &my_var in the address box and you get a memory dump with binary and ASCII from that address onwards
Posted : 16/03/2010 4:52 pm
 Earl
Thanks for the replys.
Can do all the above for specific chars but Im debugging lots and lots of preexisting code so its not pratical. I remember in a prev version VS6.0 it would show me both.
Posted : 16/03/2010 5:00 pm
