Viewing 5 posts - 1 through 5 (of 5 total)
  • Bike maintenance – how do i ….
  • Gooner
    1. Change a cassette & what tools do i need (shimano xt)
    2. Change front rings & what tools do i need (shimano deore)
    is it worth buying the tools getting the gear off the internet and doing it myself?
    thanks
    Biffer
    To change the casette you need a casette tool and a chain whip.
    To chage the rings you need an allen key and a screwdriver or better is a shimano ring key.
    Definately worth getting the tools or borrow off a mate.
    MrNutt
    I do believe the Park website to be your friend: http://www.parktool.com/index.asp
    Biffer
    …oh and as for doing it check the Park Tools website for Sheldon Brown website – should have all the details you need.
    bomberman
    you’ll need a wrench with the appropriate cassette lockring remover attachment and a chainwhip to stop it rotating as you turn it anticlockwise.
    Plus to change the chainrings you might need a chainring bolt tightening tool – if you look on the back of the chainring there’s a slot. othewise you probably won’t be able to nip the chainring up tight.
The topic ‘Bike maintenance – how do i ….’ is closed to new replies.
